跳转到主内容
Nintendo DS 的后继机种 Nintendo DS Lite 于2006年发布。这款设备的拆解和维修十分简单。
"A" button doesnt work can this be fixed?
Hi my a button on my ds lite doesn't work it isn't responsive at all. Can this be fixed?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
已选择的解决方案
Sure, use the following guide to get to the buttons rubber pieces and buttons.
Nintendo DS Lite Buttons Replacement
Make sure your buttons and rubber are clean and not sticky. If they are sticky clean them with rubbing alcohol and a paper towel. Make sure the hard black dots on the rubber are all even and not popped out. Then clean the brass colored "contacts" on the motherboard where the rubber makes contact with the motherboard with rubbing alcohol and a brush. You can see them on the pictures in step 16 here:
Nintendo DS Lite Buttons Replacement. Wipe the motherboard with a paper towel to ensure that any residue is removed. When the motherboard is dry assemble the DS Lite back together. It should work now.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Jalila 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 3
总计 15,175
