跳转到主内容
苹果 iPhone 5s 于2013年9月10日公布。该设备的维修与以前的型号相似,需要螺丝刀和撬棒。可使用GSM或CDMA / 16、32或64 GB。颜色有银色、金色和太空灰。
3530 个问题 查看全部
Why my jack play only one earphone after replacing the lightning port?
Hi
I have problem with my Iphone 5s. After lightning connector replacement (iPhone 5s Lightning连接口更换) I completly lose sound in one of earphone on any earphones that I connected and I don't know what is the reason for this. When I tried connect "old-damaged" module of lightning with old jack socked, the problem is same.
Do you know what is wrong with it? How can I fix it?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
6条评论
My guess is an issue in the audio circuit on logic board which requires diagnosing via schematics and microsoldering.
Otherwise physically damaged charging port connector.
完成的
Do the earphones work fine on another device?
完成的
Yes, it works great with anther devices
完成的
have to tried both headphone types, 1/8 inch and lightning connectors?
完成的
No, because I don't have headphone with lightning connectior. Anyway I would like to use standard jack as it is in Iphone 5s. I use my own headphones Sennheiser (not Apple product)
完成的
显示更多的1条评论
添加一条评论
3个答案
已选择的解决方案
That's what I'm thinking. You need to test a different pair of headphones, to rule that out. If the problem continues to persist, get your new Lightning dock exchanged. If that continues, then likely the Qualcomm. Which is not an easy repair, unless you have all the equipment and the experience to use it
iPhone 5s Lightning Connector and Headphone Jack
This is how to contact iFixit for an exchange
http://help.ifixit.com/article/136-email...
iPhone 5s Lightning Connector and Headphone Jack图片
产品
$24.99
这个答案有帮助吗?
得分 6
5条评论:
Thank you very much for your response iMedic! As I said, I tried connect old iPhone 5s Lightning Connector with damaged charging port and working jack and problem doesn't disappear, but I think about new connector to test it for sure! Im going to buy new one and check it out. I will let you know what is the result.
完成的
Ok, today I ordered new one part and Im waiting for delivery. Keep your fingers crossed :) Estimated delivery time: friday
完成的
Why didn't you test another pair of headphones before purchasing this part?
完成的
I tried to connect another headphones and problem is same
完成的
Ok. Then we move onto testing a known good Lightning dock. One you know for certain is 100% working
完成的
添加一条评论
Maybe there is simpler solution for my issue?
这个答案有帮助吗?
得分 0
2条评论:
did you try your phone with a different headphones?
完成的
Yeah, dude. We've both told you a couple times, to test new headphones to rule out the headphones being the problem
完成的
添加一条评论
I don't understand it at all! After replacement part (twice!) is same and now I have not vibration and + volume button doesn't work :( (I didn't touch them!)
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Bartłomiej Jakubczak 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 2
总计 175
