Why my jack play only one earphone after replacing the lightning port?
Hi
I have problem with my Iphone 5s. After lightning connector replacement (iPhone 5s Lightning连接口更换) I completly lose sound in one of earphone on any earphones that I connected and I don't know what is the reason for this. When I tried connect "old-damaged" module of lightning with old jack socked, the problem is same.
Do you know what is wrong with it? How can I fix it?
6条评论
My guess is an issue in the audio circuit on logic board which requires diagnosing via schematics and microsoldering.
Otherwise physically damaged charging port connector.
由 Ben 完成的
Do the earphones work fine on another device?
由 Cameron 完成的
Yes, it works great with anther devices
由 Bartłomiej Jakubczak 完成的
have to tried both headphone types, 1/8 inch and lightning connectors?
由 hogdoctor 完成的
No, because I don't have headphone with lightning connectior. Anyway I would like to use standard jack as it is in Iphone 5s. I use my own headphones Sennheiser (not Apple product)
显示更多的1条评论
