跳转到主内容
加入维修社区 - 创建账户
LG X Power 是一款于 2016 年 8 月发布的 4G LTE 智能手机。该机型拥有 16 GB 内存,运行 Android 操作系统。
My touchscreen not working
I had my phone in my pants pocket and it had a case on it and it rained a little bit got my pocket wet a tiny bit and after I went on lunch for work my touchscreen wont respond I reset my phone but I cant click next to set it up
回答此问题 我也有这个问题
这是一个好问题吗?
得分 4
添加一条评论
1个答案
try taking the phone completely apart, and checking all the connections and letting it fully dry out if it isn't.
make sure the touch screen is receiving power from the charging port. Let us know if this helps or if you find something, good luck!
You have to do an advanced hardware reset by first removing the battery for 30 minutes. Set a timer. After 30 mins, replace the battery and hold the volume down button for another 15 minutes. Set a timer. After 15 minutes, release the volume down and press volume up button rapidly 3 times and then immediately remove the battery again, this time, also remove the sim card. Wait about 30 seconds, and replace battery and sim.
When you power the phone back on, you should get a prompt asking you which hardware component to update., Select "screen sensor" by scrolling through the options with volume down and select it by pressing volume up. The phone will now reset the "screen sensor" hardware data and download the newest hardware update for your phone.
Screen should now be fully functional.
这个答案有帮助吗?
得分 0
4条评论:
Unfortunately i cant take the battery when i try to it bends the nattery
由完成的 分享
I have this same phone. You can't take the battery out.
由完成的 分享
never heard of an "advanced hardware reset" ...
will try it now and report the result
由完成的 分享
Well, it's like i thought, not working
由完成的 分享
添加一条评论
添加你的答案
Jango DarkWind 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 4
过去 30 天: 15
总计 6,058
