跳转到主内容
加入维修社区 - 创建账户
1.5 GHz Core Solo、1.66 或 1.83 GHz Core Duo,或 1.83 或 2 GHz Core 2 Duo 处理器。 本页面涵盖了从 2006 年初到 2007 年中的首批基于 Intel 处理器的 Mac mini 机型。
Stuck at grey start up screen
Recently my mac mini will not boot up. The mini gets stuck at the grey start up screen with the apple logo. I tried to boot from OSX install disc no success. I tried pretty much everything but to no avail. I have unplugged it, tried to reset it, no success. I ran the hardware test which I could start and it came back ok. I started the mini in target mode and was able to use its hard drive to boot and start another mini . Anyone have any ideas?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 3
添加一条评论
5个答案
已选择的解决方案
Here is a link to an Apple guide to clearing startup issues--hope it helps.
http://support.apple.com/kb/ts1417
这个答案有帮助吗?
得分 2
添加一条评论
Ok we all don't know if the failure is a HW or SW issue.
So do this:
Hold CMD + V for Verbose Mode during Startup - Where do the System hang? Write down the last three Lines.
When you don't see the spinning wheel then something with the HW need to be checked. I suggest an RAM or MLB failure. So check first Verbose Mode.
Bye
这个答案有帮助吗?
得分 1
1条评论:
hay, my macmini boots 4 to 5 times normal and then wont bootup up.. ..it only gous to blue screen.....what that coluld be? ram?
由完成的
添加一条评论
Try holding option at startup
这个答案有帮助吗?
得分 0
添加一条评论
Hi, I have this same problem, except the usb apple keyboard also doesn't respond..no caps light or anything..so I can't put it in certain modes.....this happened after a power outage in the area.
这个答案有帮助吗?
得分 0
1条评论:
Same here, anyone get an answer on this one?
由完成的
添加一条评论
the Problem is it is waiting for you to enter your password but you cannot see this on the gray screen
its a bug that has effected me in the last three updates simply type your password on the gray screen and your update will complete at least it did for me i have the mac mini 2011
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Frank 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 17
总计 31,739
