跳转到主内容
iPhone 3G是第二代iPhone。型号A1241,有8或16 GB容量,和炫酷的黑色或洁白的白色塑料背面。修复比第一款iPhone更简单。需要螺丝刀、撬撬工具和吸尘工具。
1158 个问题 查看全部
问题已关闭
My Computer recognize it as a camera
How can i change tha way my iPod is installed in my computer?? My laptop an any other computer recgnize it as a camera whenever i plug it to it... I want to use it as an external device such as a memory, just like my iPod does, i can xplore the folders in it, but im my iPhone i can see just the pictures. Plizz Help Me!!!!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Connect you phone, go into My Computer
, Right-click on your phone and select properties. Click the events tab and then select "Take No Action". But it shouldn't affect your iTunes. If your phone is not recognized, then either Mobile Device Helper is not running or is corrupt. uninstall from Add/Remove programs and reinstall iTunes and you should be good to go.
Another quick check is to go into the control panel, Admin Tools, and services and see if Apple Mobile Device is running. If not right click it, go into properties and make sure it's set to automatic and then start it.
Also, you might want to look in the device Manager under USB and see if there is any ports that might be erroring.
Here is more info from Apple http://support.apple.com/kb/TS1495 ...good luck
这个答案有帮助吗?
得分 2
添加一条评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 3,870
