跳转到主内容
加入维修社区 - 创建账户
HP Pavilion dv6500 是一款经济实惠的多媒体笔记本电脑,配备 15.4 英寸屏幕、时尚的外壳以及安全指纹扫描仪。
Why does my screen not displaying
It seems like the screen backlight is up but no display other than the blank dark screen....
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
4个答案
最有帮助的答案
This problem can be either the laptop display or the GPU/motherboard. You can test the GPU by connecting an external monitor, if the monitor displays then the problem is in the laptop display. The laptop display could have a problem with the back light, if you shine a bright light onto the display and you can see icons on the desktop then the problem is the back light. If all you see is blank then the problem is the laptop display.
这个答案有帮助吗?
得分 3
2条评论:
Thanks for your answer but I have tried using another monitor but still no display...
由完成的
The problem is the GPU on the mother board.
由完成的
添加一条评论
HP laptops are tops soldered at the factory, meaning they are baked.
A temporary fix if it dies on the road is using a hair dryer.
The permanent fix is by rebaking it.
https://www.youtube.com/watch?v=G65-ncBx...
这个答案有帮助吗?
得分 1
1条评论:
Thank's to Michael Otero for his video.
由完成的
添加一条评论
You can also try this for a reflow procedure.
http://www.deskdecode.com/how-to-fix-a-l...
这个答案有帮助吗?
得分 0
添加一条评论
You can use reflow to fix ANY top soldered board including automotive and television applications.
这个答案有帮助吗?
得分 0
1条评论:
Not always. Most of the time yes, but there are exceptions
由完成的
添加一条评论
添加你的答案
Nsikan Udotung 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 19
总计 1,013
