跳转到主内容
加入维修社区 - 创建账户
Wii Remote 是任天堂于 2006 年 11 月 19 日发布的游戏主机 Wii 的原始主控制器。初代 Wii Remote 的型号为 RVL-003。
Wii Remote speaker cable broke.
I accidentally snapped the red wire of my Nintendo Wii Remote’s speaker. What should I do to fix this?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
Oops, i mean wire. The keyboard changes the text.
由完成的 分享
添加一条评论
2个答案
已选择的解决方案
You will need to solder it back on, just take off about 3mm of the rubber casing of the wire and heat it up until it melts.
这个答案有帮助吗?
得分 2
2条评论:
When soldering you do not melt the wire ^_^
You need to use new solder to solder it back on.
由完成的 分享
@neotil i didnt mean the wire casing, i meant the solder.
由完成的 分享
添加一条评论
If you want a proper fix, and don't have a soldering iron or the courage to try, the cheapest way is to find a local electronics repair shop and ask them to resolder it for you. They should have a minimum charge, but for such a small job - it should be possible to simply have it done on the spot and get you going.
To repair this, with a soldering iron, you could attempt to gently reheat the solder just enough to melt the positive red speaker wire back into the existing solder.
Or to redo the job, with some some solder wick, you would heat the existing solder for the red (+) wire with the wick placed in between until it melts and gets soaked by the wick. Ensure the connection surface is clean, or gently wipe with some flux to prepare to solder the red wire, and simply resolder it.
Not having the actual tools for a small job is likely to be cheaper at a repair shop, given that the person is honest and does not charge a whole lot for a few minutes of work, again I would expect a minimum 1hour charge but no more.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Santi12008 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 25
总计 862
