跳转到主内容
Model A1181: 1.83, 2, 2.1, 2.13, 2.16, 2.2, or 2.4 GHz Core 2 Duo processor
1203 个问题 查看全部
No chime, no start
Hi,
I had to open the macbook and removed the keyboard,
since I could not insert the harddrive.
The problem that the glue of the flexible strip one side for the housing of the harddrive
was loosen and the strip blocked the SATA connection.
I fixed that, but then the startup failed.
No chime, and no booting at all.
Battery will be charged, when I plugin the magsafe.
Any ideas
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
The most common problem when this happens is not getting the keyboard to logic board cable seated (it's very easy to disconnect). See step #12 of this guide:
MacBook Core 2 Duo Upper Case Cable Replacement
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Markus 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 1
总计 78
