跳转到主内容
加入维修社区 - 创建账户
Genio 属于雀巢 Nescafé Dolce Gusto 系列的第二代产品,这是一款由 Arno、Krups 和 De'Longhi 制造的浓缩咖啡机/咖啡胶囊系统。其“企鹅”般的外形使其极易辨认。
Stoped working at all
My dolce Gusto stoped working when connected to electricity. Light does not even appear
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
8条评论
Does it work when its not connected? When did this occur? How long have you had it?
由完成的
My machine is only 5 months old. In 2 years I had 3 machines
由完成的
Hi got a Nescafé Dolce gusto machine and input a discaler through it yesterday as not running quite so smoothly . Did it and rinsed it through all ok. I went to use it and nothing the red light come on then the green been when it's a constant green unmove the swit h over to hot and nothing happens ? Any ideas
Thanks
由完成的
Have the same problem, how do you resolve it?
由完成的
ive had my Krups Piccolo Xs Manual Coffee Machine for 2 days i used it once now not working, no lights on, cant even take pods out it seems jammed? ive tried different sockets, assuming its not the fuse as its only couple days old, any ideas? please i need a coffee hahha
由完成的
显示更多的3条评论
添加一条评论
3个答案
最有帮助的答案
I think you should check your Dolce Gusto Genio’s mainboard(motherboard) or power port.
Then I think you could fix it.
Have a good day^^
这个答案有帮助吗?
得分 1
3条评论:
looks like that signal form switch (hot water lever) goes to main board, but then what?
Maybe you know where should I start?
由完成的
I'm sorry, I misinformed you earlier.
Let me correct what I said earlier.
I think your Dolce Gusto fuse is broken so it doesn't working.
Here's a link to a YouTube video that tells you how to fix it.
Link : https://www.youtube.com/watch?v=aja0DsBO...
Link for your Dolce Gusto's fuse (SF129E) : https://www.amazon.com/SF129E-SEFUSE-Cut...
I hope you'll be able to repair it.
Have a nice day.
由完成的
ahh thank you for a suggestion, checked my fuses.
But all of them looks normal.
So still looking for my problem
由完成的
添加一条评论
it happened to me months ago and finally fixed it today. The on/off switch consists of a piece of conductive rubber that makes contact with the circuit underneath. In my case the circuit or rubber became misaligned or dirty.
Either way what fixed it was to disassamble the switch side carefully, remove the switch rubber, clean it and the circuit with some q-tips dabbed with alcohol and reassamble all.
Deassembly was the biggest pain.
这个答案有帮助吗?
得分 0
添加一条评论
There are two thermal fuses in the back, above the boiler. Replace them both.
这个答案有帮助吗?
得分 0
1条评论:
You’ll have to take it apart.
由完成的
添加一条评论
添加你的答案
Suzan 将永远感激不已
浏览统计数据:
过去 24 小时: 5
过去 7 天: 58
过去 30 天: 174
总计 38,012
