跳转到主内容
加入维修社区 - 创建账户
苹果公司于 2015 年 9 月 25 日发布的 iPhone 6s 维修信息与指南。型号:A1688、A1633
iPhone 6s boot loop
I replaced the screen on my iPhone 6s and I followed to ifixit handbook and everything and when I went to power the screen on. I started getting a boot loop. I took it to a repair shop and they said they couldn't find what was wrong. I've tried all the boot loop methods online and I've tried restoring. Nothing has worked. I've been told the mother board has been fried by research and I don't understand why that's so. Nothing looks broken everything looks the way it should
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 7
4条评论
Have you tried changing the battery?
完成的
Yes.........
完成的
Maybe there is a short in the LCD connector or light ic or cap
完成的
The screen that is not original can cause bootloop in this case try another screen
完成的
添加一条评论
2个答案
已选择的解决方案
I know you said you tried all of the boot-loop suggestions but you don't tell us which ones. So for the record, I'll post some ideas below and tell us if there's anything in there that you haven't tried. That way we'll be able to help a you a bit more.
A few things to consider:
Try these things (if you haven't already) to see if anything helps:
  • Try a hard reset (Home & Power button for 10 secs)
  • Use a genuine Apple Lightning connector
  • Use a genuine Apple charging brick and let it charge overnight
  • Try to connect it to different computers (mac/pc if possible) with an updated iTunes
  • Put the phone in recovery mode (search DFU Mode). Careful, this can reset your data
  • Use 3uTools for putting it in and out of Recovery Mode
  • Use 3uTools to flash the firmware (you can't downgrade)
  • Check the condition of all the flexes (with magnification)
  • Disconnect the Front Camera Ribbon from the logic board and reboot your phone
  • Disconnect the screen assembly completely and see if iTunes will recognize the phone.
Otherwise, you probably have a logic board issue. If you are uncomfortable doing these steps, consider finding a repair shop that does micro-soldering; they can go deeper if the problem is not modular in nature.
这个答案有帮助吗?
得分 8
4条评论:
Your answers are good as always :)
Also OP exactly how long does it stay on the apple logo then shut off and boot up again? This can tell us what areas of hardware faults we should be looking at.
完成的
I tried the hard reset. And I just tries the disconnecting the camera. It had about a 5 minute boot loop and just sated on the black screen. Let me ask one question that might help. When I did the screen repair I didn't disconnect the battery. Could that be a problem?
完成的
Not disconnecting the battery prior to the removal of the screen can certainly cause problems with the backlight circuit.
However, I would be more concerned that you may have caused Long-Screw Damage. That is when you accidentally put a long screw where a short screw would go (usually on the Display bracket). If you didn't keep track of the screws and their placements, this is a real possibility.
At this point, I would consider finding a repair shop that does micro-soldering to properly troubleshoot your phone.
完成的
I make this tes : Disconnect the screen assembly completely and see if iTunes will recognize the phone. I itune don't detect my iphone is it normal ?
完成的
添加一条评论
It may be caused by the baseband PMU pseudo soldered.
这个答案有帮助吗?
得分 0
1条评论:
What is the baseband PMU and where on the logic board can it be found please
完成的
添加一条评论
添加你的答案
Andre Warren Jr 将永远感激不已
浏览统计数据:
过去 24 小时: 8
过去 7 天: 39
过去 30 天: 147
总计 48,076
