跳转到主内容
The tenth generation Ford F-Series is a line of pickup trucks that was produced by Ford Motor Company, it was sold from the 1997 to the 2004 model years.
83 个问题 查看全部
Where is the backup light switch located?
F-150 Supercab 4X4 Auto Trans Bulbs OK no lights in reverse Power to No 5 Fuse Fuse is good. (Under hood power distribution box) All fuses and relays tested OK.
??Faulty switch?? 2003 F150 XLT 4WD Triton V8
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 5
9条评论
Thanks oldturkey03 - All functions seem to be working except for the backup lights, so for now I will assume that the TR sensor is working OK. I will now attempt to trace the wiring to the backup lights looking for a short or broken wire. Can you tell me which mini fuse and/or relay is associated to the backup lights?
完成的
Dumb question but did you check the bulbs and their connection? My Suburban has lose connections and does this with daytime lights. If I recall on my 2003 Expedition (Built on a F-150) it should be on the left stick, but It broke down 3 or 4 years ago so it has been a while.
完成的
Yes I did, and both bulbs tested good. I tested the connections at both bulbs, and both showed a closed circuit, which leads me to suspect a short somewhere. However, I am going to repeat the test, but this time with both bulbs out at the same time. I think that maybe leaving the right side bulb in while testing the circuit at the left side was giving me a false reading, and visa versa. Maybe do this tomorrow - pouring rain right now! And it is not a dumb question.
完成的
@iamretired I would not be so quick as to dismiss the TR sensor. I think that beast is merely using a cam system from the shifter linkage to close a switch. I believe there are some adjustments you could make. check original answer for wiring update
完成的
Thanks old turkey03 - Me thinks the next thing I will do is to enlist my neighbours help and check out the switch adjustments, It sounds like a two person job, one to work, and one to watch.
完成的
显示更多的4条评论
添加一条评论
2个答案
已选择的解决方案
@iamretired it does go through the transmission range sensor. The Transmission Range (TR) sensor , which is located at the manual lever on the transmission is an information sensor for the powertrain control module (PCM). Among its functions are those normally handled by a conventional Park/Neutral switch: it prevents the engine from starting in any gear other than Park or Neutral. and closes the circuit for the back-up lights when the shift lever is moved to Reverse. The TR sensor also contains the sensing circuit for Neutral in 4X4 Low range on 4WD models.It should be located on the shift lever side on the transmission.
Update (05/08/2017)
Looks like if you place a jumper between the LtBlu/Pnk wire and the Blk/Pnk wire it'll bypass the reverse sensor and should turn your backup lights on. If so, you know its your TP Sensor that has failed.
这个答案有帮助吗?
得分 6
添加一条评论
My reverse backup lights on my 1999 F150 are staying on. Even if ignition Is off and the key is in my pocket. Does this sound like a stuck relay?
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Tom Richards 将永远感激不已
浏览统计数据:
过去 24 小时: 10
过去 7 天: 48
过去 30 天: 165
总计 22,946
