跳转到主内容
加入维修社区 - 创建账户
Insignia Flex 8 是一款由 Tianshi Digi-Lando 生产的多功能平板电脑,可以连接互联网、拍摄照片并使用各种应用程序。
Why does my tablet keep rebooting.
sometimes it start up completely to the home screen, but when i try to open any app even the web browser, it will open the app and then restart. It's really frustrating, I have done factory reset. when i try to do hard reset, the android shows up on the screen and says no command. can you please tell me how to solve this issue.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
4个答案
已选择的解决方案
When I select recovery a little robot comes up with an exclamation mark and says no commands. I have done a wipe data/factory reset and the tablet still keeps rebooting.
这个答案有帮助吗?
得分 1
添加一条评论
最有帮助的答案
Hi there,
It's a somewhat tricky procedure to get it into its recovery menu to reset it, may take a few tries to get it right but here's how...
WARNING THIS WILL ERASE ALL DATA, PICTURES, AND SETTINGS!
1.)Power tablet off
2.)Press and hold power + volume up
3.)When the "Insignia" appears, release power button but continue holding "vol up"
4.)A small list of words appear in top left corner
5.)Release volume up button
6.) Use (volume down) to select "recovery Kernel", then press (volume up).
7.) Wait a second, and a robot will appear.
8. )When the robot appears, press both the "Vol Up + Vol Down" buttons together... this may take several attempts to get it but eventually you will get a list of commands, one of which is "Wipe data/Factory Reset". Highlight it using the "Vol Down" and then "Power" to select it.
9.) Then you'll see a confirmation screen, so again "Vol Down" to move, and "Power" to select.
10.) now the system will reboot, this will take a couple minutes
这个答案有帮助吗?
得分 2
1条评论:
Does not work.
完成的
添加一条评论
No idea what to do to fix this tablet starts going on and off over and over…. Help…
这个答案有帮助吗?
得分 1
1条评论:
Im having the same issue but instead of the Insignia logo popping up i get www.mdg.com??? what do I do and why is mine so much different them everyone else's? I went to the website but this device isn't even on the MDG.COM WEBSITE ANYMORE IF IT EVEN WAS.
完成的
添加一条评论
my tablet keeps going b ack to black screen and it takes me back two where to google home page. so can we fix this with no cost for free.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Caitlyn Mquay 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 11
总计 6,193
