跳转到主内容
加入维修社区 - 创建账户
HTC 第三代智能手机,于 2015 年 3 月首次发布。相较于 M8 设计,其主要改进包括八核 Snapdragon 810 处理器和 2000 万像素后置摄像头。
HTC One M9 G-Sensor problem, a solution?
Hi, I have a HTC one M9, few days ago the smartphone fell to the ground and since then the G-Sensor doesn't work. I have done the calibration using HTC code( *#*#3424#*#* ) but nothing!
I think it is a hardware problem, is there a solution?
Thanks for your time!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
最有帮助的答案
There possibly is! Exactly the same thing happened to me and I thought it was time for a new phone. I assume you've tried to calibrate your sensors (go to 'help' - 'troubleshooting' - 'Display and buttons' - 'The display doesn't rotate automatically' - 'G-Sensor', then test and 'calibrate G-Sensor'). Apparently if you do this several times this can fix the issue, but it didn't fix mine. I then came upon the 'drop fix'. If you've dropped your phone, as I did mine, it can put the sensor out. So you use the same method to put the sensor back in again! Hold the phone about 6 inches above a thin carpet or pad of paper and drop it onto each corner in turn. Then drop it flat on its back and again on its front. Hey presto, mine started working again. Hope this helps!
这个答案有帮助吗?
得分 3
6条评论:
Thanks, mine started working again too!
完成的
Really glad to hear it, An. There's nothing worse than that sinking feeling of thinking you've broken your phone!
完成的
Awesome! It really worked. Thank you.
完成的
Glad to hear it Marco. Stay safe!
完成的
Brilliant! Another phone saved, another user comforted in the dread of having broken their phone! Thank you so much.
完成的
显示更多的1条评论
添加一条评论
添加你的答案
Valerio Tregatti 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 16
总计 1,428
