跳转到主内容
加入维修社区 - 创建账户
Fingerprint sensor not working water damage
I recently dropped my phone in water and after I dried it off the speakers worked fine and everything seemed perfect accept for when i tried my fingerprint again. I attempted to delete and redo the fingerprints but I had no luck. Any help?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
2条评论
After a glass of water fell on my phone the fingerprint sensor did not work despite my phone is fine but finger sensor not work , any possible solution ???
由完成的
Yes I also had the same problem but after I tried everything the fingerprint didn't work or even show in the settings again
由完成的
添加一条评论
3个答案
已选择的解决方案
Unfortunately, the only solution was to get the sensor replaced by a professional which was a bit pricy. But my fingerprint sensor is working just fine now.
这个答案有帮助吗?
得分 1
1条评论:
I tried everything but eventually put on radiator on a towel overnight and then reinstalled updated security software, switched it off and on and the scanner was back in my settings
由完成的
添加一条评论
最有帮助的答案
Did you ever find a solution? Same happened to me.
这个答案有帮助吗?
得分 1
1条评论:
由完成的
添加一条评论
1) You may clean your mobile and then play a high bass song on your mobile
2) then keep your phone work continuesly working for about 2 hours
3) as the processor gets heat up plat the song again to release the hot air inside your mobile then go to sleep with your mobile shut it at power of keep it off all night long and next day delete all your fingerprints then restart your mobile by putting it in flight mode add your finger print it will work I did the same after what happened to my phone
这个答案有帮助吗?
得分 1
1条评论:
Same thing happens with my mobile it fall into toilet basin then I bring it out wash with soap and water then keep it on sun...for a day from back side still fingerprint was not working then very next day I kept it on sun for half days from screen side ..then it works perfectly then it use to work on past...
由完成的
添加一条评论
添加你的答案
Patrick De Castro 将永远感激不已
浏览统计数据:
过去 24 小时: 4
过去 7 天: 10
过去 30 天: 56
总计 18,665
