跳转到主内容
加入维修社区 - 创建账户
三星新旗舰的大号版本,盖乐世S8+。发布于2017年4月。
Fast charging not working properly
Hi!
A week ago, I received my galaxy s8+ as a pre-order. The phone worked properly, until it didn't charge fast anymore... everytime I plug in my charging cable (the same cable and adapter that came with the phone) a pop-up appears saying that it can only charge slow and I had to be sure that the charger was plugged in properly. I then tried cleaning the port with a thin plastic stick. This worked for about an hour, whereafter it stopped working. Until now, it still takes 6 hours for a full charge..
Does anyone know how I can clean the port properly, without damaging it?
Thanks in advance!!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
3个答案
已选择的解决方案
I'd take it back for warranty. Sounds faulty to me.
这个答案有帮助吗?
得分 2
4条评论:
@benjamen50
Thanks for your reply!
I Will bring it back.. however, I did root my phone. Is it possible that i can unroot the phone and then bring it back for warranty?
由完成的 分享
I don't know about that though because it will say knox warranty void 0x1 in the download mode on screen which technically means warranty voided so you can only try.
由完成的 分享
Sometimes if you buy refurbished device, these problems are normal.
Fast charging can get damaged when the device is opened and repaired.
https://www.bestphonerepair.com.au/galax...
由完成的 分享
It could even be the root (as it uses different kernel) stopping fast charging from working if it happened right after rooting it.
由完成的 分享
添加一条评论
I had the same symptoms and warning messages. Fix was simple - dust/fluff had got into the charging port. A quick squirt with a can of compressed air, and everything was back to normal.
这个答案有帮助吗?
得分 1
添加一条评论
Have you tried checking settings to see if fast charge is enabled?
Sounds stupid but i found that to happen once or twice on mine.
also you could purchase a USB voltage detector online which are a few quid,
and see the voltage going in to the phone?
Hope this helps.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
nabil 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 21
总计 9,267
