timing chain tension can it be done with out the special tools
For a BMW 740iL, BMW require you to use a special tool to adjust the tension on the timing chain for a M62 series 740iL V-8 5.75liter engine dated 08-1998?
Looks to me that all you need is 19mm deep socket. Check out what the expert at http://forums.bimmerforums.com/forum/sho... show you and see if that is the information you need. Good Luck....
这个答案有帮助吗?
过去 24 小时: 2
过去 7 天: 6
过去 30 天: 13
总计 1,330
