跳转到主内容
加入维修社区 - 创建账户
Asus ROG Strix GL702VM-BHI7N09 是 Asus 于 2017 年 1 月发布的一款游戏电脑。
Should I replace my battery?
It seems like the battery life of my laptop just continuously gets worse and worse. It doesn't last as long as it did when I first acquired the laptop, and I'm worried that it won't get any better or stop anytime soon. Does this happen with laptop batteries?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
This is a pretty common issue with laptops, though often the issue isn't caused by a bad battery. A common cause for short battery life is old or outdated software. Old software tends to absorb battery life faster than the new updated software, while sometimes causing lower overall computer performance also. Try updating to the latest software and see if that helps your battery issue. If this doesn't fix the issue, you might have to replace the battery. Check out the troubleshooting page for the Asus ROG Strix GL702VM-BHI7N09 for more information.
Hope this helps!
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Samuel Porter 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 6
总计 1,873
