跳转到主内容
加入维修社区 - 创建账户
Portege R705-P25 笔记本电脑属于 Toshiba 的 R700 笔记本系列
Time keep changing after set in control panel
Time incorrect. It can be changed in Control Panel, but it will change again showing an incorrect time. Date is ok.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
For this type of issue, there are only a couple of things I know of to check.
First, make sure you are set to the right time zone. This can usually be done as easily as right clicking the clock -> Adjust time/date -> Select correct Time Zone in drop down
If it keeps happening, I have solved this issue before by replacing the CMOS battery which seemed to be the culprit.
Hope this helps!
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Alberto 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 10
总计 349
