跳转到主内容
加入维修社区 - 创建账户
HP Pavilion g6 笔记本电脑的维修信息与故障排除。
Overheating on left hand corner.
After 10 plus minutes left hand corner of machine gets hot. Eventually almost too hot to hold. Fan appears to be going.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
1条评论
you can read here for solving
https://www.knowerstech.com/hp-pavilion-...
完成的
添加一条评论
3个答案
已选择的解决方案
Hi,
Left hand front or rear?
Are the fan vents clogged?
Does the laptop shut down of its' own accord?
Here is a link to the service manual for the laptop.
It will help in the dis-assembly of the laptop so that you can check that the fan is OK and not clogged etc. and also to ascertain where the heat is coming from.
这个答案有帮助吗?
得分 6
1条评论:
https://h30434.www3.hp.com/t5/Notebook-S...
yes its the chip with small metal heatsink but not connected to fan. how do you think i can get cooling solution hack for this
完成的
添加一条评论
same here, my fan area is perfectly clean. im blaming the 3rd chip in that area which i dont know what it is. but i havent open case after running it to prove it. hot area is what u rest you left palm. what to do its too hot
这个答案有帮助吗?
得分 0
添加一条评论
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Mike 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 8
总计 6,664
