跳转到主内容
iPhone 6s Plus 发布于2015年9月25日,有两个型号A1687、A1634,网络制式有GSM、WCDMA,存储容量有16GB、64GB、128GB可选,机身颜色有银色、金色、深空灰、玫瑰金。维修iPhone 6s Plus和前代产品相似,需要螺丝刀和撬棒等。
Rotation sensor is messed up?!
Hello everyone,
I have iPhone 6S plus and it seems like the rotation gone insane.
The screen rotates to left side with no obvious reason and doesn't rotate when I want.
I also noticed that it affects the raise to wake function.
My device isn't jailbroken and to solve this issue I force restart the device. Simple reboot doesn't do it..
I thought it might be an IC issue...
anyone here can help me locate the cause of this problem and perhaps a fix?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
5条评论
This happen outta nowhere? Screen replacement? Recent drop?
完成的
Seems like it came out of nowhere no traumatic drop I can recall...
完成的
Ok. It happens super weird, but it happens
完成的
Any solution you can offer me to try? Tried software update but nothing..
完成的
I had a problem with screen rotation
Thought gyroscope was fukd, turns out an update messed things up..
this is how fix: Jus turn off and restart your phone
完成的
添加一条评论
1个答案
已选择的解决方案
I'm gonna go with liquid damage. Yes, I agree this is going to sound super weird and not what you wanna hear. I'm gonna guess sweat. It happens. My guess is the gyroscope has been blown. Likely a InvenSense 6-axis gyroscope and accelerometer combo. You probably have other liquid damage that is minor and can't notice it. I would recommend an ultrasonic bath, at a good repair shop. And have em replace that part. You probably could kinda do the water damage cleaning yourself. I'll post a couple guides. But I would recommend bringing it/mailing it to a good board repair shop
iPhone 6s Plus 主板更换
Electronics Water Damage
It's the pink one. To the left of the orange one
这个答案有帮助吗?
得分 4
4条评论:
Luckily I'm a technician myself, fix phones everyday... can you direct me to the IC that is responsible for the gyroscope? Had troubles finding it online..
完成的
Just preordered a simple logic board disassembly and didn't see any noticeable water damage...will look under a microscope later today I hope and will preform ultrasonic bath later this week I hope
完成的
Added a new picture to my answer. That's supposed to be the culprit
完成的
Yeah also found it on Ifixit website. Thank you very much sir
完成的
添加一条评论
添加你的答案
npodp1 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 4,533
