iPhone 5 crazy touch
hi, the display on my iphone 5 has gone mad, writes on its own or does not respond alone opens app
Usually iPhone 5 (or any iPhone for this matter) that does "ghost touching" or "typing on its own" needs to have the display replaced.
Possible causes:
- Bad replacement screen assembly - the screen was replaced before and a poor copy screen was used;
- Damage from drop/liquid - the screen was original or replaced but was later damaged;
- Battery swollen, pushed it from inside and damaged it.
这个答案有帮助吗?
Try a reboot pressing together the home+power button until you see the apple logo appear. If that doesn't help there's not much you can do apart from changing the screen.
这个答案有帮助吗?
If touch can not work well, in most cases you have to replace screen.
But we can replace the touch/digitizer in China.
But... iphone screen is very very cheap now, if your iphone screen is original, it is worth to repair, if cope then buy a new copy screen :)
这个答案有帮助吗?
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 5
总计 5,058
1条评论
Hello,
Is it a Genuine screen or was it a replacement?
I had this problem when I replaced my one.
Regards
Ricard
由 ricardo 完成的
