跳转到主内容
苹果官方于2015年9月25日正式发售iPhone6S A1688/A1633机型。 此机型的修理方式与先前几代差不多, 需要螺丝起子及撬棍工具。 同时也适用GSM or CDMA/16, 64 or 123 GB/ 银色, 金色, 深空灰色, 玫瑰金色等机型。
2690 个问题 查看全部
Power button not functioning
I have a fairly new iPhone 6S. About 1 month after buying the phone the power button stopped working. I already followed the iFixit guide to the point where I could unscrew the power button and check everything.
I have not yet replaced the flex cable though, since the volume buttons and flash work perfectly.
A second problem arises when calling: a lot of crackling noises to be heard through the earspeaker. When recording through voice memos the playback is fine through the earspeaker.
Anyone got an idea? Is it possible the power button broke by itself only after 1 month of using, whilst volume and flash continue to work?
Would the earspeaker problem be caused by the antennas or something?
There's no warranty anymore on the device.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
I mean, the phones been out for a year and a half now. Yes, those things could be not working, while the other things could be working, on the same ribbon cable. Even though the cost of parts is very cheap, these are extensive repairs, and plenty of room for things to go wrong. Anyways, here's some parts and guides. Take your time and double check everything
iPhone 6s Front Camera and Sensor Cable
[关联产品丢失或禁用: IF314-030]
iPhone 6s 前置摄像头与光线传感器组件更换
iPhone 6s 上元件排线更换
iPhone 6s Front Camera and Sensor Cable图片
产品
$22.99
iPhone 6s 前置摄像头与光线传感器组件图片
指南
难度:
中等
1 - 2 hours
iPhone 6s 上元件排线图片
指南
iPhone 6s 上元件排线更换
难度:
困难
1 - 3 hours
这个答案有帮助吗?
得分 2
2条评论:
Thank you for your reply. Yes the phone has been out for a while, but the power button already stopped working after 1 month of buying it.
But the earspeaker problem is likely a completely separate problem? Or could it be an issue with the logic board causing the issue of the power putton and crackling while calling?
完成的
Well, you'll want to test the front camera flex, as that part has the ear speaker, because it's a relatively simple repair, and you'll want to rule that out. The power button means you have to remove everything, and then find out. I am wondering about any software possibilities, but really sounds like a hardware thing
完成的
添加一条评论
添加你的答案
FD Tech 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 1
总计 75
