跳转到主内容
Repair guides and teardowns for Samsung feature phones. This category is for phones not using an Android or Windows operating system.
209 个问题 查看全部
The Samsung SGH-F700 screen is cracked, correct spare part?
I am using a Samsung SGH-F700 i borrowed from my boss.
The screen (the most external plastic layer) cracked right in the middle without me to drop it or bumping into something, i think it was because of torsion in the pocket (i wasn't using the cover because it was impossible to feel the vibration).
Since the first crack, new cracks are popping every day, even if i'm using the cover!
Luckily the touchscreen is still working!
I have to give the phone back asap, i went all around town to ask for repair, but nobody want to fix it: the phone was bought in Italy, but i am in Namibia (Africa), where this phone was never sold. I'm located in the Capital.
I ask you if this spare part
http://cgi.ebay.com/Touch-Ecran-LCD-Digi...
is correct, so that i can try to fix it myself.
I'm doubtful because, as stated above, the touchscreen is working.
Thanks
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
已选择的解决方案
Flavio, if it is the "outer layer" that is cracked, than this is the art that worked for my phone. This digitizer is the outer layer. Just make sure that you can feel the cracks and that it is not under your digitizer that the cracks are. But I would most certainly think that this is the part that would repair your bosses phone....Good luck.
这个答案有帮助吗?
得分 0
1条评论:
Yes, i can feel the cracks (it is still worsening! the top half part of screen is almost a web).
I had some sitbacks in the ordering process, but finally the Hong-Kong seller send it and looks it will be arriving for the 6th of jan.
You had the same phone or a different? I'm looking for a disassembly guide, i guess i will just have to unscrew the body after removing the back cover, but i'd like to be sure that is not even simpler (i.e.: the digitizer would be detachable with the tools from the front).
完成的
添加一条评论
添加你的答案
Flavio Mauri 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 2
总计 1,287
