跳转到主内容
The sixth generation of the Mazda Protegé, also known as the Mazda Familia and the Mazda 323. The five-door fastback edition was known as the Familia Astina or the 323F.
12 个问题 查看全部
Why my car turns on for a few seconds then turn right off
I replace my starter with a new one, on my 94 Mazda protege Lx, Now my car turns on for like 5 seconds then it turns right back off, I push the gas padel while the car is on but it only rev once & turn back off, I'm not sure why it's happening.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
is this a manual or automatic?
完成的
添加一条评论
1个答案
最有帮助的答案
@rivera64545 , Jon, Start then stalling issues, is there security light on, bad sensors TPS, MAP, MAF, IAC, O2, failing knock senor, faulty injectors, dirty throttle body, EGR valve, major vacuum leak, failing fuel pump, bad ignition, bad distributor, plugged catalytic converter, etc.etc.. As a first step have the car scanned for trouble codes as it may identify the exact problem. Some of the auto parts suppliers offer free code reading like Pepboys, Nappa, Advanced auto parts,etc and some of the guys are very knowledgeable and may have seen the issue often and put you on the right track or see if one of your buddies have one to lend. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Jon 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 126
