跳转到主内容
Sit-on-top lawn mower. Zero-turn radius mower, 50" mower deck, hydro transmission.
68 个问题 查看全部
Cover over engine will not come off without removing tractor frame.
How do you replace carburetor when the top cover over engine cannot be removed without taking the complete frame apart?
Update (04/12/2017)
I have the Kohler engine . When I remove all the screws that secure the engine shroud, I can only raise it about an inch or two before it hits the top frame of the tractor. Therefore it will not come off until I disassemble that frame. I don't think they would have designed it this way but I see no alternative. Thanks for your responses.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
2条评论
@michael3107 the ZTS7500 comes with Kohler as well as Briggs and Stratton engines (should be a 44P777-0130-P1 or 44P777-0130) so let us know which engine your mower has.
完成的
( 26 hp 107.28791 )
完成的
添加一条评论
2个答案
已选择的解决方案
@michael3107 , Michael, I believe on that model, you have to remove the intake manifold with the carburetor attached as an assembly, then you can remove the carburetor from the intake. Watch closely or take pics of how assy comes apart so you can put back in correct order. You can get your engines manual from the links below. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
https://www.briggsandstratton.com/na/en_...
https://www.kohler-engine-parts.opeengin...
这个答案有帮助吗?
得分 4
添加一条评论
I have a older m20 magium and i have to change a coil on it i have all but the bottom back corner of it off and i can't get if off the shroud to get enough clearance its on a Grazer G2000CII model.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Michael 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 11
过去 30 天: 59
总计 5,567
