跳转到主内容
加入维修社区 - 创建账户
2003年10月,iBook G4 取代 iBook G3 成为苹果的消费级笔记本电脑产品。iBook G4 提供12英寸和14英寸机型,最后更新于2005年。
DVD player wont read.
I place a (DVD) disk into my iBook G4 and it takes it, makes a sound like its starting to "think" for about two seconds, then spits it back out.
However, it reads CD disks with no problems.
I have a DVD player on the computer, so why won't it load?
I have also tried to play Sims 3 (for Mac, obviously) and the same thing -(spitting it back out)- happened.
Please help
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
3个答案
已选择的解决方案
First, you need to know how the optical drive works. Basically, there is a different laser for each purpose. For example, there is 1 laser for CD read and another for CD write. When the optical drive is used continuously, some lasers might get misaligned. The result is that you will lose that function. I believe your DVD read laser has become misaligned, so if you want to read DVD's, you have 2 options:
1. Replace the drive.
2. Buy an external drive. They can be found for about $50 at any electronics store. Most of them can even write DVD's!
Hope this helps!
这个答案有帮助吗?
得分 4
2条评论:
+ agreed, an external will even move to your next Mac.
完成的
+ agreed on the external but make sure you get a firewire version so you can boot from it.
完成的
添加一条评论
It will not read because your iBook does not have a Super drive like mine. When you get an iBook, You have 3 options for it. cd read drive, DVD read drive, and the super drive which burns and reads cds and dvds. you must have the cd one because mine just reads cds and it makes a very loud noise, then slows down and spits it out. I read by apple that mine has a cd only drive. this might be your problem.
If you want it to read discs, you can:
Replace the cd drive with a super drive yourself. (only if you know what your doing)
or get a external dvd/cd drive reader. (Might be pricy)
Hope this helps! ~Sean
这个答案有帮助吗?
得分 0
1条评论:
Oh, i didnt see someone already answered this!
完成的
添加一条评论
All iBook G4s have at least a Combo drive, which can read DVDs. Optical drives can sometimes have a failure that affects one kind of disk, but not the other. If you have this issue, replace it. This goes for all laptops, by the way.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
ic101spots 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 8
总计 3,842
