跳转到主内容
Released in 2006, identified by model number PP20L for e1505
How to determine SATA controller revision in Windows.
Short and sweet: how do I know how fast the SATA interface will be from windows (10). I'm not talking about the HDD.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
1个答案
已选择的解决方案
@pccheese I'd start with a good benchmark program to get that information. You probably already know that there are two factors that determine the speed: the interface/controller and the device i.e. HDD. Try HWiNFO or SiSoftware Sandra. If you use HWINFO, navigate in the device tree to Bus > PCI Bus #0. Under PCI Bus #0, click on the SATA AHCI Controller device. Details about the controller will dhoe in a pane that you can then scroll through to find a heading "SATA Host Controller" with the Interface Speed Supported
这个答案有帮助吗?
得分 4
1条评论:
Thanks oldturkey03. I found that it is sata I. The theoretical speed of SATA is about 180 MB/s, but the real speed is around 150. Do you think an SSD will do any good if it's throttled down by the interface?
I've narrowed it down to two:
This crazy fast HDD: https://www.amazon.com/gp/aw/d/B01LYNQXC...
Or my favorite SATA SSD: https://www.amazon.com/gp/aw/d/B01F9G43W...
Thanks again.
完成的
添加一条评论
添加你的答案
George A. 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 6
总计 1,359
