跳转到主内容
加入维修社区 - 创建账户
Eclipse 180BL 是一款配备 1.8 英寸 LCD 显示屏的媒体播放器。 该设备由 Mach Speed 制造,型号为“180BL”。 为确保你拥有的正是此款型号,请查看设备背面上的型号名称。 它应该位于设备背面的中央,以白色粗体字母标出。 此设备的型号显示为:“Eclipse 180BL 8GB”
I need to replace the USB port
can I replace the USB port
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Hi,
Here is a link to the ifixit repair guide for the battery for the player. It is handy in that it shows how to open the player so that access to the USB port is possible.
Here is an image taken from Step 3 (2nd image) which shows the connector.
(click on image to enlarge for better viewing).
It is possible to change the connector, however you will require the appropriate soldering skills and tools to perform the task. Also the hard part may be finding the correct replacement part. There are a lot of mini USB female connector configurations available. (Different number of pins -4 or 5, location of holding lugs etc.)
Here is a link to one supplier (This one may be suitable I'm not sure though that the "lugs" which hold the connector to the pcb are in the correct spot and also it might be upside down to the version that is installed already). It is not a recommendation to use them, it is shown to give an idea of the cost of the part. There may be others online that suit you better.
Hopefully this is of some help.
这个答案有帮助吗?
得分 3
添加一条评论
添加你的答案
Wayne myers 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 10
总计 332
