跳转到主内容
加入维修社区 - 创建账户
一款 HP 于 2011 年推出的平板电脑,运行 webOS 平台。配备 9.7 英寸显示屏,提供 16 GB 或 32 GB 版本。维修过程直观,但需要时间和耐心。
Display problem in middle of display
My display has developed a 2" bar across the middle that is all garbled or fuzzy meaning you can't read or see what is supposed to be there. Otherwise the unit works well. Is there a way to fix this problem? Thanks in advance for any help
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
likely the pins in your LCD connector are likely built up with dirt. Open the device, remove the LCD connector. use a toothbrush and 99%isopropyl to scrub at bot the gold traces at the end of the flex, and inside the female connector of the board. Air dry for 10 minutes, and reconnect.
This SHOULD Fix your issue.
If it does not, either the flex is damaged, or the connector on the mother board is damaged.
-if the flex is damaged, replace the LCD
-if the connector is damaged, remove the connector, and solder a new one onto the board. (This last step is a more difficult procedure, and without SMT Soldering experience, i would suggest taking it to a professional.)
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Peter Mather 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 17
总计 334
