跳转到主内容
这是Google公司生产的第一款智能手机,Pixel XL(型号:G-2PW2100)发布于2016年10月20日。其配备5.5英寸AMOLED显示屏,3450mAh电池和32GB或128GB可选存储空间。
WiFi Antenna Replacement Procedure For Google Pixel
after getting the phone wet, I am having issues and facing a WiFi struggle after 3 hours later. it will not connect unless the phone is actually on the router itself. I'm not sure if its because its still wet, or that it actually got damaged completely but i would like to know is there anything i can do to repair this myself, and where the antenna is located and if there is any parts to replace this online or on any stores.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 3
1条评论
How did you solve this problem? I have exact same problem on mine. Any help from your side will be really appreciated
完成的
添加一条评论
1个答案
最有帮助的答案
Brandon Tenney, Antenna seems to be a chip soldered to the board(seen in step 11 of the guide below).
If the phone was not treated properly for water/corrosion damage Stop charging or powering up your device until the liquid damage is addressed correctly, as you could be shorting out components inside the phone. You really should take care of the corrosion that is happening inside the phone from the water damage as that could be your problem. A tear down link for your device Link #1, disassembly guide will enable you to get inside the phone to remove the damage/corrosion caused by the liquid. Use the 2nd link as a guide/instruction on how to clean/repair the device from liquid damage. After this you will be able to power on the phone and see if further damage has to be addressed. Good luck.
Google Pixel XL 拆解
Electronics Water Damage
这个答案有帮助吗?
得分 3
添加一条评论
添加你的答案
Brandon Tenney 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 14
过去 30 天: 49
总计 6,746
