跳转到主内容
The Jeep Cherokee (XJ) is a compact SUV that was manufactured and marketed by Jeep from 1997 to 2001. Sharing the name of the original full-size SJ model, but without a traditional body-on-frame chassis, the XJ instead featured a light-weight unibody design.
40 个问题 查看全部
Where is the oil pressure switch located?
Where is the oil pressure switch located on the motor?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
已选择的解决方案
On the 2000 inline 6 it is down on the block just above the oil filter. Look for a small cylinder with a wire on one end
这个答案有帮助吗?
得分 3
添加一条评论
On the 3.7L engine it's at the front of the engine above the oil filter, remove filter for better access. Unplug the wiring harness by moving the red safety tab and depressing the lock tab. Requires 1 1/16" deep socket to remove.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Debbie 将永远感激不已
浏览统计数据:
过去 24 小时: 4
过去 7 天: 7
过去 30 天: 15
总计 3,977
