跳转到主内容
加入维修社区 - 创建账户
Samsung Galaxy J2 是一款于 2016 年 11 月发布的 Android 智能手机。
turn off safe mode
how to disable safe mode I'm already try all think but no work please replyme fast because I need some app
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 8
添加一条评论
1个答案
已选择的解决方案
There are several ways to disable safe mode . Some phones you need to just shut off and reboot . Others need be rebooted from the android menu. Select boot normally . You can also try removing the battery. Then reinstall it and reboot. or you can also go to the android menu and select wipe cache partition. One of these should reset your phone to a normal boot. Hope this helps
这个答案有帮助吗?
得分 10
4条评论:
Safe mode off samsung j2
完成的
Hi @ Rohit Chudasma,
As @jimfixer said to turn off safe mode on Samsung Galaxy J2:
Press and hold the Power key.
Tap Restart.
完成的
Safe mode disable krne ka kya
完成的
if the safe mode was locked with PIN code and didn't know the code
完成的
添加一条评论
添加你的答案
Rohit Mudgal 将永远感激不已
浏览统计数据:
过去 24 小时: 4
过去 7 天: 8
过去 30 天: 20
总计 20,605
