Can someone fix the HDMI 2 port, which has pushed in?
The HDMI 2 port has somehow become mangled; it ;looks like it has been pushed in, and I don't know how to pry it out or whether prying it will damage it. Are there people I can hire to do this?
yes, Yes the HDMI 2 port can be repaired, yours could be soldered directly to a board which takes some skill to reattach if undamaged or replace if need be. Any good local TV repairman or computer repair shop can probably perform this task. The link below will give you an idea of what is involved in the repair of a loose HDMI port. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
这个答案有帮助吗?
yes, did this help answer your question.
过去 24 小时: 3
过去 7 天: 5
过去 30 天: 28
总计 6,636
3条评论
yes what exact model is your TV?
由 oldturkey03 完成的
If you want to try to fix this, you probably need to take the tv apart. And if it is bent, its pretty much screwed anyway as some pins probably broke which are a pain to fix
由 Cameron 完成的
Bless you! I will look for a computer repair or TV repair person. Thank you so much.
由 yes 完成的
