Loud hiss when turned on
Suddenly when I plug in and turn on my speaker there is a loud hiss.
I've tried different power cables and plugging into different outlets.. The hiss is evident whether or not there is a sound source plugged in.
这是一个好问题吗?
Device and repair information for the Behringer Eurolive B212D speaker system.
声誉积分: 11
@townband , Steve , Unplug speaker and use the guide below to disassemble the speaker and spray switches with electro-contact cleaner and remove, spray and reseat connections to see if that gets rid of hissing. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
Disassembling Behringer Eurolive B212D Power & Control Panel
评论:
I will check it out. Again, the last people to use it were outside and unsupervised.
Who know what they did to it!
由 Steve 完成的
Steve, Good plan, look for water damage also then, if it does appear to have some on the board use this general guide link below, to to help clean of possible corrosion. Thanks for replying back, good luck with your speaker.
由 L Pfaff 完成的
A hiss or buzz in a speaker system usually indicates a poor ground at the speaker . A solder joint may have let loose so that the wires still attached but not a good ground . You'll need to take it apart and check the grounds. Hope this helps
评论:
Great thought. I will try it out. The last people to use it were outside unsupervised! Thanks.
由 Steve 完成的
过去的24小时: 1
过去的7天: 5
过去的30天: 19
总计 1,207
