跳转到主内容
加入维修社区 - 创建账户
发布于2015年3月,并在2015年4月10日上市。盖乐世S6是盖乐世家族又一部旗舰机型。其曲面屏版本被称为盖乐世S6 Edge。
My internal memory chip
Is there any way I can get my stuff off of my internal memory chip and place it on a sd card? My phone will not turn on nor will it charge. When the battery was replaced the phone got hot when it was connected to a charger to charge.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
Maybe the charging port is the issue? Perhaps the contact is loose and a lot of heat gets produced when all the charging current must go through a small area.
完成的
添加一条评论
1个答案
已选择的解决方案
@ee_major you can only get files off your phone if you get your phone to start up. You cannot retrieve anything from a dead board since the memory is a soldered part of the motherboard and cannot simply be placed onto another board.
这个答案有帮助吗?
得分 5
2条评论:
So when the board is dead, the chip is dead? Is it possible to remove the chip and put it on a working board to get the info off of it?
完成的
Since full disk encryption is mandatory on Android 6.0 and above, it is not likely you get any readable info either a chip-off or replacing it on to another board. The chip itself is a BGA95 style chip and would require you to have the right tools and some really good skills to accomplish the transplant. If the data is very vital to you I recommend you try one of the many data recovery companies out there.
完成的
添加一条评论
添加你的答案
Zakia Gregory 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 6
总计 5,045
