跳转到主内容
iPhone 6s Plus 发布于2015年9月25日,有两个型号A1687、A1634,网络制式有GSM、WCDMA,存储容量有16GB、64GB、128GB可选,机身颜色有银色、金色、深空灰、玫瑰金。维修iPhone 6s Plus和前代产品相似,需要螺丝刀和撬棒等。
1041 个问题 查看全部
Water Damaged and wont turn on
My iPhone was in my pocket and i fell asleep this is embarrassing but i wet the bed from drinking a lot i guess and i woke up my phone screen was white i could still see the time and everything and swipe but couldn't unlock it with my code i left in rice for the rest of day now it wont turn on at all. Is there anything I can do?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
Arop A , The rice would have done very little to help your phone as it is not a very good at liquid absorption, make sure to clean the rice out of all nooks and cranny's. Stop charging or powering up your device until the liquid damage is addressed correctly, as you could be shorting out components inside the phone. You really should take care of the corrosion that is happening inside the phone from the water damage as that could be your problem. A tear down link for your device Link #1, disassembly guide will enable you to get inside the phone to remove the damage/corrosion caused by the liquid. Use the 2nd link as a guide/instruction on how to clean/repair the device from liquid damage. After this you will be able to power on the phone and see if further damage has to be addressed. Good luck.
iPhone 6s Plus 拆解
Electronics Water Damage
这个答案有帮助吗?
得分 2
添加一条评论
Putting the phone in rice probably didn't help. Some components may be shorted internally, so you should avoid using the device or charging it to prevent internal damage. From your description it sounds like there may be issues with the display, as well as more extensive damage.
Below is a teardown of the phone, and also some guides to help with liquid damage to phones.
iPhone 6s Plus 拆解
修复iPhone 的进水故障
iPhone图片
指南
修复iPhone 的进水故障
难度:
困难
1 - 2 hours
iPhone 6s Plus图片
指南
iPhone 6s Plus 拆解
难度:
中等
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Arop A 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 2
过去 30 天: 2
总计 1,282
