跳转到主内容
由华硕制造的笔记本电脑。
2520 个问题 查看全部
How do I split screen
how do I split the screen to look at two windows
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 3
1条评论
I do not now how to split screen can you help me.
完成的
添加一条评论
3个答案
已选择的解决方案
Left click and hold on the top of the screen you want to split then drag it to the edge of the screen . When you hit the edge of the screen the page will split. Then drag the other page you want to split to the other side of the screen . If your using a browser you need to have 2 windows open you cant split tabs. So open that tab in another window. This is done by right slicking on the tab you want and selecting move to new window.Then you can split the screen. This is in windows 10 . Hope this helps
这个答案有帮助吗?
得分 6
添加一条评论
jenhump depends on what version Windows you are running and what you mean by splitting the screen. In Windows 7 and Windows 8, you no longer have to follow the Windows XP procedure for splitting windows because there is a new feature called Snap. Using Snap, you can just drag windows around the screen and they will “snap” into place. Check here for more.
这个答案有帮助吗?
得分 6
5条评论:
@oldturkey03, congratulations on getting to 400k reputation! Something to work towards.
I would be honored if you joined my Team. I created it because the regular master techs has to many inactive and wanna be techs. https://www.ifixit.com/Team/21339/Master...
完成的
@oldturkey03 Hey Wow 400K now there's a milestone . To master of manuals , the keeper of the Greybeards , moderator and keeper of the peace , fixer of gadgets and of men, congratulations Mike!!!
完成的
@oldturkey03 , Congrat's on the 400K, That is amazing!
完成的
@oldturkey03 ,
Well done! A magnificent achievement.
完成的
@jayeff @pccheese @jimfixer @lpfaff1 Thank you very much. Couldn't have done it without you gentlemen. I appreciate what you all do here on Answers...
完成的
添加一条评论
Yet again rephrasing what both @oldturkey03 and @jimfixer have said, simply open the two programs you want to look at together, click at the top and drag to the side of the screen. When you do this, the other program will want to line up on the other half. Alternatively​, you can hold down the Windows key and use the directional buttons to move to the sides.
这个答案有帮助吗?
得分 6
1条评论:
on windows 10 and the snap feature doesn't work sometimes, not sure why but holding windows button was such an easy fix thank you @pccheese
完成的
添加一条评论
添加你的答案
jenhump12 将永远感激不已
浏览统计数据:
过去 24 小时: 8
过去 7 天: 76
过去 30 天: 339
总计 29,618
