跳转到主内容
加入维修社区 - 创建账户
The Kenmore Elite HE3 is a washing machine by Kenmore. It is identical to the Whirlpool Duet.
Washer buttons won't stay on
When I press the power button, all lights power on then right back off. I replaced the dispenser PCB assembly, but that did not change anything.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
1条评论
Washer won't stay on. Lights do come on but turns off or just flashes. What could this be???
完成的
添加一条评论
2个答案
已选择的解决方案
First unplug it for five minutes to allow it to reset.
That failing take a look at my answer here:
Cycle light flashes, but machine wont start
这个答案有帮助吗?
得分 2
添加一条评论
@kodiakbear ,laurinda59 , unplug the washer for 5 minutes, then plug it back in and listen for a click. If no click possible bad CCU, also could be door lock switch faulty or bad connection, start switch and or timer faulty, washer motor faulty, main control board faulty or shorted. Check the links below for more trouble shooting info. the last link is the service manual that could help big time in diagnosing your issue. Good luck.
https://www.youtube.com/watch?v=YdWuLw15...
http://removeandreplace.com/2015/04/10/w...
Repairing Kenmore Elite HE3 Washer Control Board Relays
Duet-Aid_also-Kenmore-HE3.pdf
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
laurinda59 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 3
总计 5,863
