跳转到主内容
The eighth generation of the Mitsubishi Lancer.
What is the best way to remove the alternator on a 2006 lancer 2L DOHC
I have a 2006 lancer 2.0L DOHC and the alternator is on the passenger side at the bottom of the motor which is the best way to get the alternator out does not look like it can com me straight out the top
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
This question was migrated from http://meta.ifixit.com/Answers.
完成的
添加一条评论
2个答案
已选择的解决方案
@scullyjunior , Chris, It will come out the top with some wiggling/rotating/pulling. The link below has a pretty good step by step procedure for you to check out and image from link may also help. Good luck.
http://www.justanswer.com/mitsubishi/783...
这个答案有帮助吗?
得分 2
添加一条评论
Be aware its not as easy as it looks or seems in this car since the a/c line is right dead center of the alternator and the lower control arm is directly below it it definitely takes much longer frustrations then they say took me and my dad 4.5 hrs of cursing and snapping to get the old one out took less time to get the new ine in then it did to get the old one out
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Chris 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 7
总计 425
