跳转到主内容
Repair information for the 6th generation iPod nano. Released in September of 2010. Model Number: A1366.
175 个问题 查看全部
iPod Nano 6th Generation LCD Adhesive Recommendation?
Hi all,
I just replaced an LCD on my nano. Looks good. Works fine. Only problem I am experiencing it with the adhesive. I bought the custom precut adhesives from ebay but they seem a bit too narrow. When placed on the ipod they seem to sit a little below in the recessed area so the LCD doesn't make enough contact with it to stick.
Anyone have any adhesive recommendations?
Thanks!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
2个答案
最有帮助的答案
@gob15 , Christopher, The 1st link below shows the recommended tape to used in the ifixit disassembly guide 2nd link. Good luck.
[关联产品丢失或禁用: IF145-283]
iPod Nano 6th Generation Front Panel Assembly Replacement
这个答案有帮助吗?
得分 3
4条评论:
Thanks for the links. Were there other options for the tape? The LCD I bought was the same price as the tape and shipped free! The shipping on the tape is half the price of the tape itself.
完成的
@gob15 search on eBay for the red "ultra sticky double sided tape", thin, strong and cheap
完成的
@reecee, @gob15 , Reece, thanks for the input,I believe this is the stuff in the link below.
http://www.ebay.ie/itm/2mm-25M-Ultra-Sli...
完成的
Thanks. That tape does seem thinner than even the pre-cut adhesive being sold for the nano. I can give it a try though and see how it works out.
完成的
添加一条评论
Hi Christopher, also absolutely vital is to clean all surfaces with alcohol before trying to stick down. Also, I found that leaving the backing tape in place on the cable side until you have got the screen ribbons tucked in, really helps. Good luck ☺☺
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Christopher Cross 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 9
过去 30 天: 17
总计 1,263
