跳转到主内容
The fourth generation of Honda Accord covering model years 1990 through 1993 available in coupe, sedan, and wagon chassis.
46 个问题 查看全部
My 1990 Honda accord EX-R hood latch is bent inward, how do I fix it?
I rear ended someone a couple weeks ago and i got a new hood for my 1990 honda accord but my hood wont shut flush. I looked at my hood latch and it is bent inward, is there anyway i can fix it myself, if so, how?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
diego tamesis , If you are talking about the hood latch on top of rad support they can be bent out fairly easy. Tie a rope/chain/cable around the area of the latch/cradle and the other end wraps around a 2x4, put a rag between 2x4 and bumper, now use the 2x4 to pry the hood latch/cradle into correct position. May have to fine tune with a heavy hammer and board. Ifyou are not removing any thing such as radiator,A/C condenser,etc. take your time and be careful as you do not to damage other parts. See the link below, same idea, just not as drastic. Good luck.
https://www.youtube.com/watch?v=Zr4grivK...
这个答案有帮助吗?
得分 4
7条评论:
Thank you so much! appreciate it
完成的
diego tamesis, your welcome, I have actually had to do this before on a friends car. If you like the answer, accept it thanks.
完成的
Hi @lpfaff1 ,
Is a 'heavy hammer' also known as an American screwdriver where you are as well? ;-)
完成的
jayeff, :-))) I have not heard it termed that way, but maybe by some!
完成的
I had heard of that but the urban dictionary has: http://www.urbandictionary.com/define.ph...
完成的
显示更多的2条评论
添加一条评论
添加你的答案
diego tamesis 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 12
总计 1,159
