跳转到主内容
The third-generation HTC One smartphone which was first released in March 2015. Its major revisions on the M8 design include the octa-core Snapdragon 810 processor and a 20-megapixel rear camera.
71 个问题 查看全部
How to get data from a powerless phone?
3 days ago, my phone was washed for about an hour. My phone will not turn on, but the charging light keeps blinking on and off when I plug it into my computer. I do not know if my battery is dead or the actaully phone broke.
How do I get my apps and pictures from the phone?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
3个答案
已选择的解决方案
jacob de la rosa , Remove memory card if there is one. Quit charging/powering on device until you have treated for liquid damage as instructed in the guide below(1st link) Techniques for generalized water damage troubleshooting and recovery and 2nd link for dismantling your device to clean of liquid damage/corrosion. This may even get your phone up and running. You may have to consult a data recovery service. Good luck.
Electronics Water Damage
HTC One M9 Teardown
这个答案有帮助吗?
得分 4
1条评论:
If you do manage to get the phone running the first thing you should do is remove you data . The Phone likely wont run long
完成的
添加一条评论
@lpfaff1 Has told you how to restore your phone which is what you need to do to recover your data and apps. There is no other way to recover the info than to repair the phone . Follow L Pfaff s instructions and hope for the best . One last thing , dont put it in rice , this will not help.
这个答案有帮助吗?
得分 3
添加一条评论
Well if you pull the logic board and put it on a new phone it will work but clean the board first and all contacts or take the storage drive off of the board.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
jacob de la rosa 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 4
过去 30 天: 6
总计 1,475
