Toughbook CF29 Screen Replacement
Is it possible to replace the hole display of a Toughbook CF29 without opening an breaking the seal?
Thx
I do not think that this is possible. The only way would be to replace the whole top part, however, your cables will have to be disconnected on the inside of the panel. So I guess you will have to split the halves and reseal them after. Personal I think you will do fine with some silicon after as suggested. Good luck
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 7
总计 1,193
1条评论
I have the replacement part numbers if you need them to your toughbook.
just post the full model number (example: CF-29C3KGZ1M)
由 S0U1SB4N3 完成的
