跳转到主内容
首先 你得要准备一部iPad Air(1rd Gen)只支持Wi-Fi的机型 这里我们指的是A1474机型 它拥有64位的A7双核处理器并拥有16,32,64GB甚至是128GB的内存选择
299 个问题 查看全部
Damaged Pads on Logic Board
Hi Guys,
I've been given an iPad Air with charging issues. Having opened it up, it's clear that someone has already tried to attempt a fix and managed to damage pads in the process (Where the Dock and Speaker ribbon connects to the Logic Board).
Let me know if you think it's worth trying to fix. I'm hoping a fine wire bridge might be possible. Any advice on how to go about this would be greatly appreciated.
Thanks in advance!
Ben
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
5条评论
I am also curious about this
完成的
Also would it be fixable to do this for U2401, touch ic on iPhone 6+?
完成的
bennyboy399 any chance you can zoom out and take a straight picture? No artistic expressions required.
@theimedic what are thinking off? Trying to figure out what your plan is:-)
完成的
i also have same board that i totally ruined, if i jumper pin 46 into pin 2 will that work?
完成的
添加一条评论
4个答案
已选择的解决方案
bennyboy399 lets start you off with identifying what those pins do. I attached the images that are pertinent to that. Pins 1,2,46,47 are marked. So all you have to do now is clean up your connector and see what purpose those pins have.
Here is the layout of the pins
Now marked on your image
and here is the schematic
Compare that to the pads that are missing on yours. Looks like Pin 22 is completely missing, which would be ground. 24 still seems to partially there and could be fixed (need a cleaner and better image)
这个答案有帮助吗?
得分 4
1条评论:
What are the chances that you have the schematic for the power connector for the iPad 7?
完成的
添加一条评论
Put flux on and clean up the pads. Get a board view and schematic and see what those pins do. Could be easily fixable if those pins are ground, check what they are. They could be speaker, home button, charge port, etc.
这个答案有帮助吗?
得分 0
添加一条评论
hello guys arethe schematic same for ipad air two?? got same case!! some pads are missing but i dont know where to bridge them! i cant find clear guide on internet! please help
这个答案有帮助吗?
得分 0
1条评论:
Unfortunately they are not. I would also like to know where the pulled pads lead on pcb. I have schematics but i don‘t have the layout view for ipad air 2, can anyone help me?
完成的
添加一条评论
See closest track to broken pin then trace it back with continuity tester till you can piggy back a connection of a testing port or side of componet make sure not to create a short should be no trouble with micro scope and small soldering iron and a lot of patience if you feel like you getting stressed take a break
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
bennyboy399 将永远感激不已
浏览统计数据:
过去 24 小时: 4
过去 7 天: 18
过去 30 天: 61
总计 5,273
