跳转到主内容
A transforming "laplet" in the Lenovo Yoga line.
9 个问题 查看全部
My laptop wont start cause of fan error help
my laptop recently made a weird noise then said fan error and shut down i need this as it is my school devices now when i turn itt on it doesnt even turn on and say fan error it starts to turn on for about 1 sec then turns off help me pleasssssssssssse
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
2条评论
Well done. blew into the air outlet and yeah boots and all is well all the best to you!
完成的
It is easy. Replace the CMOS battery: D
完成的
添加一条评论
2个答案
已选择的解决方案
there are a few things you can try first is to reseat the fan plug . This involves taking the back of the computer then finding the fan and simply unplugging it then plugging it back in. while your there you can reset the memory so it has a clear clean boot . This is done by disconnecting the battery and then pressing down the power button for 60 seconds . you can do this when you unplug the fan . This video will help with opening the laptop
https://www.youtube.com/watch?v=egbkSCGR...
You dont need to remove the battery just unplug it will do.
Hope this helps
这个答案有帮助吗?
得分 6
4条评论:
thank you so much i will try this
完成的
worked great!
完成的
way cool it worked huff and puff blew air into like a harmonica... boots well now
完成的
Wow!!! It works like a magic thank you so much
完成的
添加一条评论
@dahlz18100 besides the excellent answer provided by my colleague, you can also check this site and replace the fan to fix the shut-down error.
这个答案有帮助吗?
得分 4
添加一条评论
添加你的答案
dahlia pear 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 17
过去 30 天: 32
总计 29,585
