跳转到主内容
加入维修社区 - 创建账户
2014 年发布的 RCA 7 英寸平板电脑(型号 RCT6773W22)的维修与故障排除指南。
My tablet won't charge
why won't my tablet charge
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 4
添加一条评论
2个答案
已选择的解决方案
@shiningstar15, Carly , A lot of forums feel a factory reset can fix this type of issue, read and follow the steps in the first link below if you would like to try, all data not backed up will be lost.
Reset did not work, either the cable or charge port may be damaged. Look in the charge port and blow/pick out(carefully) any dust/debri that may be causing an issue. Try a different compatible charger/cord to see if that is the issue. If different compatible charger/cord does not fix, it is probably a damaged/loose port that will have to be repaired/replaced. If port looks/test good the battery or connection is probably bad.
If port is found to be bad, this is really not a repair for the inexperienced because the charge port for your device is soldered to the mother board and the heat generated could cause further damage if not very careful. I will post a link to a tear down guide to get you inside the tablet to check the charge port and will also post a link showing what is involved in repairing a mini USB attached to the board (not your exact device). If not wanting to do the repair yourself have a good computer/cell phone repair shop have a look and estimate repair. Another option would be to do a search for a good replacement complete motherboard which as an assembly would be fairly easy to change(last link MB less then $15.00). Good luck.
http://unlockandreset.com/rca-tablets-al...
RCA RCT6773W22 主板更换
https://www.youtube.com/watch?v=YxxpLYf1...
http://www.ebay.com/itm/RCA-7-034-Genuin...
这个答案有帮助吗?
得分 3
添加一条评论
try factory reset if that doesn’t work then take it to professionals they know what to do
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
carly 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 7
过去 30 天: 20
总计 6,511
