跳转到主内容
screen broken- how to get a cheap replacement?
Hi all,
I have a macbook pro here with broken LCD. The apple repair shop was going to charge me 700 dollars to do the repair.
I'm confident I can install the screen myself, I'm just not sure if I should get just the panel, and if I should also get the cable from the computer to the panel, or if I should just get apple part number 661-4342 like they recommend, which is the full assembly that can be ordered from Apple.
thanks,
B
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
3个答案
最有帮助的答案
You can get a used one here for $218: MacBook Pro 15" (Models A1226/A1260) LCD Panel
or a new one here for $295: http://www.dvwarehouse.com/Apple-LCD-Dis...
MacBook Pro 15" (Models A1226/A1260) LCD Panel图片
产品
$179.99
这个答案有帮助吗?
得分 1
2条评论:
hi mayer
thanks for point me to the right links- i'm not sure if it is the LCD panel that is broken, or the cable going from the display to the LCD panel. is there an easy way to figure this out?
thanks!
b
完成的
Only if you have the spare parts. If the screen is broken, does it come on at all? If you see a desktop, forget the cable. Why would you suspect the cable when the screen is broken? Hook it up to an external monitor to see if all else is working.
完成的
添加一条评论
If you want to troubleshoot the cable and screen separately, get a spare/new cable first (given the cheaper price I suppose) and you should be able to pinpoint the problem from there.
If you end up needing to buy a new screen instead, you can always resell the cable.
Maybe obvious, but my 2 cents nonetheless ;)
这个答案有帮助吗?
得分 0
1条评论:
This makes perfect sense and is a smart way of doing some troubleshooting. Great advise...:)
完成的
添加一条评论
Info for UK users ...
I recently needed a new screen for my MBP. I had the nvidia graphics card problem last year which Apple replaced for me free of charge, but this time the screen had gone completely and it needed a new panel. Apple quoted me £370 for the replacement.
I did not want to undertake the replacement myself but I found a company in the UK who will do it for you. I can heartily recommend David at Mactuition near Bath:
http://www.macbookscreen.co.uk/Home.html
He replaced the screen for me for £199 plus £15 postage. I think his price has now increased to £229 plus postage though. I sent the MBP to him by post on Friday and it was back with me on Wednesday.
Having just upgraded the RAM and hard disk myself using the instructions provided here on ifixit, I might be tempted to do the replacement myself in future, but at the time I was nervous about doing what seemed such a large job. Plus the professional service from David was little more expensive than sourcing a new panel myself.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
bert schiettecatte 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 1
总计 5,409
