跳转到主内容
Logic Board Part Number
Serial Number Of Mac C02FCTUVDH2G
MLB C0210970K6QDMLPAM
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Apple MacBook Pro "Core i5" 2.3 13" Early 2011 Specs
Identifiers: Early 2011 13" - MC700LL/A - MacBookPro8,1 - A1278 - 2419*
Apple Part # 661-5869, 661-6078
To upgrade go here:
MacBook Pro 13" Unibody (Early 2011-Late 2011) 2.7 GHz Logic Board
MacBook Pro 13" Unibody (Early 2011-Late 2011) 2.3 GHz Logic Board
MacBook Pro 13" Unibody Early 2011 Logic Board Replacement
Replace a 2.3 GHz logic board (motherboard) compatible with the Early 2011 to Late 2011 13” Unibody MacBook Pro laptop. Included Ports: FireWire 800, Thunderbolt (Mini DisplayPort), 1000BaseT Ethernet, 2 USB 2.0, Audio In/Audio Out, SD card slot. Fix processing issues like unexpected shutdowns, reboots, or water damage.图片
产品
$59.99
Replace a 2.7 GHz logic board (motherboard) compatible with the MacBook Pro 13" Unibody (Early 2011-Late 2011). Included Ports: FireWire 800, Thunderbolt (Mini DisplayPort), 1000BaseT Ethernet, 2 USB 2.0, Audio In/Audio Out, SD card slot. Fix processing issues like unexpected shutdowns, reboots, or water damage.图片
产品
$89.99
这个答案有帮助吗?
得分 3
3条评论:
Thank You
The part number of logic board?
完成的
I put it Bold so you can see it.
完成的
Ok Ok i see Thank you
完成的
添加一条评论
添加你的答案
falcontech 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 641
