跳转到主内容
加入维修社区 - 创建账户
iPad mini 4 LTE 版本(型号 A1550)维修指南。iPad mini 4 于 2015 年 9 月 9 日发布,是 iPad mini 3 的后续机型。
About to replace screen/digitzier - sleep/wake sensor
I'm about to replace my wife's iPad Mini 4 LTE's LCD/digitizer (fused). The guide says to remove the connector with 6 solder pads on it, the home button, and some posts talk about a component that affects the sleep/wake function of the iPad.
Appreciate any help with some concerns:
1.) The 6 pads that need to be desoldered and resoldered, is it better to release it with a heat gun or use a soldering iron and peel it slowly away?
2.) How do I know if the replacement screen/digitizer has the component needed for the sleep/wake function
3.) Should the replacement not have it, what does the component look like and how do we remove it? Soldering Iron? Heat Gun?
Thank you all! (m _ _ m) (kneeling)
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
You want to remove it using a soldering iron with a small hoof tip, at the lowest temperature your solder can handle. Using leaded solder here will make your job a lot easier. Pop a small amount of flux paste on the existing joints before desoldering, too.
I'd recommend against using a heat gun - the kind of heat needed to melt the solder would destroy the plastic flex - or desoldering wick/braid, for a similar reason.
It'd be pretty obvious if the new display assembly doesn't already have the sensor, as there will be an exposed copper pad array in that location, ready for a sensor to be soldered onto it.
This is what the part looks like:
这个答案有帮助吗?
得分 3
3条评论:
Any idea on where I could buy a replacement sensor?
完成的
Where in the world are you, Ryan? I'm based in the UK, so can only really make recommendations for here.
完成的
Any idea on where I could buy a replacement sensor in the UK?
完成的
添加一条评论
添加你的答案
greenbubby 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 18
总计 2,162
